BusinessObjects Board
Explorer/Polestar Error WIS 10901?
I’m stumped.
We are running BOXI3.2 against a SSAS Cube in SQLServer 2008 r2 and getting the following error intermittently when indexing “spaces”
Server, CLE3SBOP11.PolestarIndexing, generated the following messages:
Index Creation Failed (The execution of the specified analysis query failed.-A database error occured. The database error text is: An error occurred while trying to load the provider for transport odbo. Failed to load library . System error message: The specified module could not be found… (WIS 10901))
Anyone seen this before, or have any idea how to fix it?
So far we have:
-Rebooted the server/services
-Tried simplified “spaces”
-rebuilt the cubes
Mark
MBradbourne :us: (BOB member since 2003-08-28)
Hmm I would first test out the universe (I assuming you are using a universe built from an OLAP datasource) in webi or crystal reports to compare its response against Explorer. BTW, what version explorer are you using?
katullus :us: (BOB member since 2009-08-21)
Were you able to identify this issue and what was it?
di652 (BOB member since 2005-02-24)
