executing SQL function for tables from different datastore
HI,
Can we use SQL function in BODS to process records from table which resides in 2 different datastore/database.
shazi58 (BOB member since 2016-02-01)
Yes, if you can execute a SQL in the command interpreter of one of the databases that will have access to both via the login credentials provided to the datastore. That is a very narrow corner case and I am not sure it is what you are asking. It would occur if you had two datastores to databases that were connected as linked servers.
  • E
eepjr24 :us: (BOB member since 2005-09-16)
Thanks for the reply.
Here I am trying to join tables from diffrerent datastores/database (SQL SERVER and ORACLE) …
This is possible in DS, but not through a SQL function. You would need to do the join in memory, since neither database server can talk directly to each other or use a data transfer transform to temporarily stage the data on one of the servers so the database can perform the join for you. There is no tool that I know of that would allow what you are asking for directly, even data federators perform the joins in memory on their own server.
  • E
