I have a successful connection between SAP BODS and SAP BW.When I activate BW Process chain, I can see DS jobs executing one after the other.
In the below forum , I came to know 12.2.2.3 version supports multithreading.If anyone has overcome this problem. Please let me know how parallel execution is done in DS 12.2.2.3 .
Do we need to specify in console? or what will be the process?
As you have seen that the BOBJ DS jobs are executed by BW process chanins, can you explain if there is any special configuration to be done?
I can manually execute an infopackage and load the data into PSA, but if I use process chain to run the same infopackage, the call does not even go to the DS server!
I have limited know-how with BW. If I am missing any configurations, please let me know.
