I searched on the forum and could not get the exact answer to my problem.
I have 5 prompts. This is my hierarchy
County – Area – District – Town – Ward
When I run the report I get 5 prompts one for each. The user should be able to run the report by any one of them. I have set my LOVs.
If I select any 3 or 4 prompts, the report should exclude the prompts which are not selected. I have seen a code which sets the default values in prompts to all and shows all values in the report.But I want to exclude the promts in the report which are not selected.
Pradeep is technically correct, but there are techniques you can use to make a prompt optional. Do a search for “optional prompt*” here on BOB and you’ll find those techniques discussed. I would start with the first two postings in the Designer FAQ.
