Exception: DBD, ORA-00920: invalid relational operator
Some of our uers are getting the error - Exception: DBD, ORA-00920: invalid relational operator while they refreshing the report. The Query condition we are using is
 Account Number In list of the query result (C:\xyz.xls.Org Number)
The xyz.xls file has been placed in a common shaed location and all the users have access for this xls sheet.
Any ideas?
-Dora.
dora (BOB member since 2008-04-09)
Has anyone got it open?
Business objects needed exclusive access from what I remember.
I copied the xls sheet onto my computer and repointed (in there is no chance to open by someone), but still the same issue.
How many values are you trying to supply to your In List, Oracle has a limit of around 250 from memory?
Tank you, Mak
Your suspect is correct. No. of values causing the issue. my list contants ~6000 values. If reduce down to 1027, the report is refreshing fine, beyond that it’s throwing an error. Is there any parameter setting which can accept more values?
-Dora?
You uses Oracle database, right?
The problem that you are experiencing (the fact that IN operator can not accept more than 1000 or so values) is a limitation of the database and not BO.
I suggest to ask your Oracle DBA whether he/she knows any DB parameter that would help to extend the number of values accepted by IN operator in the WHERE clause.
Thank you, Marek.
There is no parameter to increase the number of values allowed n the IN operator. simply split the condition down into multiple conditions combined with OR s
pablolee :uk: (BOB member since 2008-07-29)
In that case, consider loading your data from your Excel sheet into the database and importing it as a table into designer then joining it.
You’d have a far more performant query then.
