Am importing .bmp into the report but while saving in excel it is not displaying the picture and i can see the table values.
Sriraman
srijackson (BOB member since 2009-07-29)
Sriraman
You are importing .bmp file in the report and if you are saving this report in your machine (local copy) it will show …but if you are exporting the report in repostiory then you open the report by import and save it in excel it will not show you the Pic.
amitrathi1234 (BOB member since 2007-10-15)
Thanks for your reply.
i can able to see the LOGO in my desktop intelligence report but if i saved into .xls in local system then it is not showing the LOGO at the report header. I can see the charts, tables in the excel format expect the LOGO.
Note : Am not doing any exporting to my Repo
As i heard while saving to an xls file only data provider values will be loaded.
Sriraman
