Excel Export, Multiple Columns, can grow - how same height?
Hey,
I have a report with multiple columns which I want to export to excel.
I know that all columns should have the same height
My problem is
-column 1: ID <- has always the same height (1)
-column 2: Date <- has always the same height (1)
-column 3: Text <- has the can grow option and can scale to quite a few lines.
So my question is:
How can I automatically scale the height of column 1 and 2 so that they have the same height as the dynamic text column.
The aim is to have an Excel export with no empy cells in column 1 and 2.
Thanks in advance
Christoph
AckermannC (BOB member since 2010-06-18)
Has no one an idea, how to accomplish this :?:
Hi guys,
Even I am having the same requirement, did any one find the solution.
AckermannC were yu able to get a fix for this?
Please let me know in the mean time I am trying some things.
Best Regards,
Milind D. Kadam
milind.kadam (BOB member since 2006-07-07)
Did you ever come up with a solution for this issue…?
MJRBIM :canada: (BOB member since 2007-03-23)
