Error: WIS 30270
Dear All,
I required your help on Error: WIS 30270…
Scenario: i am tring to run a simple report from WEBI. when i run the report, i am getting the followinG:
An internal Error has occure while calling the" ProcessDPCommands" API.(WIS 30270)
Thanks in Advance
Raghav :slight_smile:
raghav221 (BOB member since 2010-06-11)
This error may come due to multiple reasons. Usually, it arises when some kind of information is corrupt or not available (for ex Data Provider or Document ID is invalid etc).
I believe you would need to trace it down. Please go through the following thread, it may help you:
Link: Error: "processDPCommands (WIS 30270) while running Web
Please read the entire thread and try the solutions available.
P.S.: You may even like to search this forum first (in your case - Web Intelligence sub-forum), often at times you will find the question(s) answered. :slight_smile:
Rajat Sapru :us: (BOB member since 2008-08-28)
