Hi all,
I had changed the parametres settings of the server from french to english. and then I’m unable to modify the reports.
I get the following message :
your security profile does not include permission to use the web intelligence formula language (Error : WIS 30257).
even if I didn’t change any permission !!!
Thanks for support.
ily77 (BOB member since 2007-09-21)
I think you need access rights to change the default language settings.
Consult your Admin to do needful…
BOCP (BOB member since 2007-07-02)
system
May 14, 2009, 11:45am
3
Yes, this the error message I found in the guide.
but where exactelly should I verify “access rights to change the default language settings”. the user I m using is an administrator and has all the rights for different applications of BO.
thanks
