Error while running Bods job. Error code 50406
Data flow received a bad system message.
Message text from the child process is <blank
9584 9656 RUN-050406 5/7/2019 9:19:47 AM message, possibly due to insufficient memory
(use NT Task Manager to monitor memory usage during the
job)==========================================================
Collect the following and send to Customer Support:
1. Log files(error_, monitor_, trace_*) associated with this failed job.
2. Exported ATL file of this failed job.
3. DDL statements of tables referenced in this failed job.
4. Data to populate the tables referenced in the failed job. If not possible, get the last few rows (or sample of them)
when
9584 9656 RUN-050406 5/7/2019 9:19:47 AM the job failed.
5. Core dump, if any, generated from this failed job.
==========================================================>. The process executing data flow
This error occurs when validation transform is executed inside the DF.
Mimurughu (BOB member since 2019-05-07)
