When I using one measure variable with a formula in report.it gives ERROR. But when I am using formula alone in the formula bar. it gives correct value. But I have to use variable iself in the report.
I am using WebI XI R2
Please help
Bismarty (BOB member since 2007-03-13)
Please can you post the syntax as well as what product you are using.
Cheers, Mark
[Moderator Note: Moved to Web-I - Jansi]
Jansi (BOB member since 2008-05-12)
Resolved one of the variable within the formulae where condition was measure, which I changed to Dimension.
