Error when using SAP BW data only to calculate values using multiple items selected slice. (XI3.0 Voyager)
Description of Problem: Error when using SAP BW data only to calculate values using multiple items selected slice. this does not happen with sample data.
Product\Version: Voyager XI 3.0
Steps to Reproduce:
refer to attachment screenshot
- Connect to the SAP BW Data
- Create the Table.
Add the Category Dimension to Slice.
Add the Film Dimension to Row.
Add the Year Dimension to Column. - Insert the sum, count, and Minimum … Etc…
Click the Category.Napkin Dimension - Changed the Slice Member Dimension.
Select the two or three Dimension. - You will see the Error.
This is a bug???
aaaa.ppt (189.0 KB)
EunSangYoon (BOB member since 2007-01-18)
