Error"Warning: Your system is running low on virtual me
When i execute the job i see this error
“Warning: Your system is running low on virtual memory. Total size is <40185>, available space <53>”
Want to know what memory is it.
Can anyone help me out with this.
Kevin
kevinjohnson19 (BOB member since 2011-12-07)
The computers virtual memory (main memory + swap space).
Thanks for the response.
Do i need to improve my Computer memory for it.
And the error is not related to Data Services right?
Kevin
I wouldn’t go that far. The first question is, why does the DataServices process consume so much memory - assuming it is.
Either you cache large amounts of data because you have to for performance reasons or accidentally and without caching it would be even faster.
http://wiki.sdn.sap.com/wiki/display/EIM/Help%2C+my+Dataflow+consumes+so+much+memory!
http://wiki.sdn.sap.com/wiki/display/EIM/Identify+a+Bottleneck+in+a+Dataflow
I have similar situation, in which we have more than 80 scheduled jobs and we are getting this error. We are processing Master jobs that runs for more than 3 hours each.
We will not be able to make job level changes now. We are able to find a parameter -
MAX_64BIT_PROCESS_VM_IN_MB=4096
in DSConfig.txt file.
Can we increase the Virtual Memory in this parameter to a high level value let’s say increase 1 GB more?
Let me know your inputs.
Thanks…
d.ravikiran2009 (BOB member since 2011-02-16)
The only way without changing the current jobs is to increase the amount of memory available on the machine.
However, if a jobs falls over due to memory usage and you have normally 16 GB available. And you double it to 32 GB, who is to say that 32 GB is enough?
A job consuming too much memory needs to be redesigned.
And with for a example the usage of a data transfer (set to table) there are quick and dirty work-a-rounds available.
