Error - SWF Generation
Hi Guys,
I am having a problem to generate a SWF when I press Preview. I have tryed to generate SWF in three diferent machines and the problem is the same. Error:
It happens after I added new combos box mapping 500 lines for each one. In my dashboard I had to create 12 combos and if I delete those combos, it works very well. The version of my xcelsius is 5.6.0.0.
Do you have any idea? :hb: :hb: :hb: :hb:
Thank you very much,
Gustavo
defaro :brazil: (BOB member since 2006-09-01)
Odds are strong that you are running out of memory while generating the SWF. 12 500-row combos is a lot.
Hi Lugh,
Thank you for you anwser.
Actually I added only one combo to test and I had the same error. I have dashboard with more than 12 combos and it works very well. I really don´t think it is too much.
If you have more ideas, please, tell me.
Thank you!
Gustavo
what is size of the output file, I guess a large file could be a problem too.
manohar3787 (BOB member since 2012-07-30)
