Error RWI 00239
I am not able to open any reports.
I am getting (Error: RWI 00239)(Error: INF).
Can somebody help me.
Many Thanks,
Swathi
swathits (BOB member since 2011-01-03)
Cause
The maximum number of server connections allowed has been reached.
Action
Either raise the value of the maximum connections server parameter, or add another server instance.
To modify the maximum connections value:
  1. Log on to BusinessObjects Enterprise Central Management Console
    (CMC).
  2. Click on Servers.
  3. Expand Server Categories, and click on Web Intelligence.
  4. Under Server name, double-click on
    WebIntelligenceProcessingServer. The Properties window appears.
  5. In Properties window, under Web Intelligence Processing Service, enter the value for Maximum Connections.
or go through the following link
Pradeep.
av_deepu :india: (BOB member since 2010-08-11)
Av_deepu , thanks and YES your solution worked. Once again thank you. :slight_smile:
