I have been fighting with Data Service Metadata Integrator for a couple of days.
At the moment I am running the program, cmsCollector.cmd, from the command line.
Its pulling some data into the DS Repository but not the universe data. The error being displayed is:
Univere [xxxx]. Unable to parse responce from COM collector. null
Univers [xxxx]. Collection failed. Correct errors indicated in log and rerun the integrator
I have came across posts regarding changing the properies of Designer in the dcomcnfg, but Designer is not a class listed.
I will have to look at your env will it possible for you to file a support case
since you are on DS 12.1, I would first suggest trying the following
since you have only installed Metadata Integrator on BOE server, take DS 12.2.3.3 and install Metadata Integrator from that on the BOE Server (upgrade only the Metadata Integrator to 12.2.3.2) and now try to run
you don’t have to upgrade the complete DS to 12.2.3 if you don’t want to do that
