I’m building a universe on a Microsoft Access '97 Database. When I try to view the Table Values of my fact tables I get the following message : [Microsoft][ODBC Microsoft Access 97 Driver] Syntax error in FROM clause.
My datamodel has 2 fact tables and a few dimension tables. The view table values options works with the dimension tables.
When I test the universe in BO reporter I get the same error message, with an extra comment: [Microsoft][ODBC Microsoft Access 97 Driver] Syntax error in FROM clause.-3506
I’m using BO 4.1 on windows’95.
Thanks in advance for your replies.
Olaf
Olaf Prevo
EIM/ Small Business Research & Consultancy PO Box 7001
2701 AA Zoetermeer
tel.: +31 79 341 3634
fax: + 31 79 341 5024
email: OPR@EIM.NL
WWW: http://www.eim.nl
Can somebody help me with the following problem? I’m building a universe on a Microsoft Access '97 Database. When I try to view the Table Values of my fact tables I get the following message : [Microsoft][ODBC Microsoft Access 97 Driver] Syntax error in FROM clause.
My datamodel has 2 fact tables and a few dimension tables. The view table values options works with the dimension tables. When I test the universe in BO reporter I get the same error message, with an extra comment: [Microsoft][ODBC Microsoft Access 97 Driver] Syntax error in FROM clause.-3506
