Error in ebus405.jar class when trying to connect to BO4.2
I am trying to connect to BO 4.2 server via a WinAD authentication, refresh and pull a report. When I try to connect to the BO server I get the below error. The error says that TenantCategoryPolicy_impl class was not found but it is located in ebus405.jar and also the classes which are called before are located in the same jar file. We are using wildfly Application server to host the application.
at org.quartz.core.JobRunShell.run(JobRunShell.java:203)
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.java:520)
Caused by: java.lang.NoClassDefFoundError: com/crystaldecisions/thirdparty/com/ooc/OB/TenantCategoryPolicy_impl
at com.crystaldecisions.thirdparty.com.ooc.OBCORBA.ORB_impl.initializeDefaultPolicies(ORB_impl.java:369)
at com.crystaldecisions.thirdparty.com.ooc.OBCORBA.ORB_impl.initialize(ORB_impl.java:196)
at com.crystaldecisions.thirdparty.com.ooc.OBCORBA.ORB_impl.setParameters(ORB_impl.java:804)
at com.crystaldecisions.thirdparty.com.ooc.OBCORBA.ORB_impl.init(ORB_impl.java:1305)
at com.crystaldecisions.enterprise.ocaframework.idl.helper.ORBHelper.init(ORBHelper.java:57)
at com.crystaldecisions.enterprise.ocaframework.ServiceMgr.(ServiceMgr.java:402)
at com.crystaldecisions.enterprise.ocaframework.ServiceMgrFactory.getServiceMgr(ServiceMgrFactory.java:66)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.ensureServiceStub(LogonService.java:645)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.doUserLogon(LogonService.java:828)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.doUserLogon(LogonService.java:805)
at com.crystaldecisions.sdk.occa.security.internal.LogonService.userLogon(LogonService.java:210)
at com.crystaldecisions.sdk.occa.security.internal.SecurityMgr.userLogon(SecurityMgr.java:166)
at com.crystaldecisions.sdk.framework.internal.SessionMgr.logon_aroundBody0(SessionMgr.java:454)
at com.crystaldecisions.sdk.framework.internal.SessionMgr.logon_aroundBody1$advice(SessionMgr.java:512)
at com.crystaldecisions.sdk.framework.internal.SessionMgr.logon(SessionMgr.java:1)
I do not understand how come I read part of the code.
:hb: :hb: :hb: :hb: :hb: :hb: :hb: :hb:
hemanthkolla (BOB member since 2016-05-24)
