(Error: ERR_WIS_30270) (FBE60502)
I am running a sceduled publication report it is giving the following error
“An internal error occured while calling ‘getSessionInfosEx’ API. (Error: ERR_WIS_30270) (FBE60502)”
Earlier there was no issue while running the report. But now i am getting this error and i temporarily resloved it by restarting webi processing server is there any permanent solution regarding this issue please share.
Thanks & Regards,
Faiz
Faiz Ahmed (BOB member since 2013-10-01)
Please, state the exact version and patch level?!
Build Number: 738
Product Version: 14.0.3
SP4
Seems like a totally outdated version, I would get on a recent patch level first!
When running an interactive report you may encounter the following error message:
“An internal error occured while calling ‘processDPCommands/getPages’ API (Error: ERR_WIS_30270)”
This message will appear if your server is running out of memory, especially if the LMS, the databases and Business Objects are all installed on the same server.
To free up your server memory we recommend that you turn off real-time caching in Business Objects as follows:
  1. Log into the Business Objects CMC
  2. Go to the ‘Servers’ area of the CMC
  3. Double-click on the WebIntelligenceProcessingServer server to open the properties
  4. Scroll down the page and uncheck the ‘Enable Real-time Cache’ checkbox
  5. Click ‘Save and Close’
  6. Highlight the WebIntelligenceProcessingServer server which should now have a flag next to it
  7. Right-click and select ‘Restart server’ for the change to take effect
Your server will now have memory available to it and you should find that the error message will not be shown.
source:
http://knowledgemanager.e2train.com/questions/326/Internal+error+processDPCommands+(ERR_WIS_30270)
Mahmood (BOB member since 2010-08-23)
