Error column ambiguously defined State
Hi guys
actually i still rookies with DeskI and right now i have a problem with 1 of report that being produced by previous developer and suddenly this report is not generated in BO folder.
after take alook on the report, i notice the sql queries is not properly working
SELECT DISTINCT
  convertaccount(CDD01.NUMCPT),
  CLD01.NOMCLI,
  CCD01.SOLCRA,
  CDD05.TYPENR,
  CLD01.PRNCLI,
  MAX(CDD33.MONRBT_CAP+CDD33.MONRBT_INT),
  CLD01.NOMALP,
  FCD03.LIBETT_1,
  CDD06.LIBPDT_1,
  CDD05.CMPSOL_22 + CDD05.CMPSOL_14 + CDD05.CMPSOL_50,
  CDD06.CODPDT,
  CCD012.SOLCRA,
  FCD03.CODETT,
  convertdate(CDD01.DATPRE_ECH),
  CLD01.TELPRI,
  CLD01.TELBUR,
  CLD013.NOMCLI,
  CASE WHEN ZZ055.CodTB1 = '05' THEN  ZZ055.LIBEL1_1 ELSE ' ' END ,
  Table__60.LIBEL1_1,
  Table__60.LIBEVT_1,
  Table__60.LIBEVT_2
FROM
  CDD01,
  CLD01,
  CCD01,
  CDD05,
  CDD33,
  FCD03,
  CDD06,
  CCD01  CCD012,
  CLD01  CLD013,
  ZZ055,
  (   SELECT FCD05.cleevt, ZZ155.LIBEL1_1, FCD05.LIBEVT_1 , FCD05.LIBEVT_2, FCD05.CODUSR,FCD05.datevt
  FROM FCD05
  LEFT OUTER JOIN ZZ155 ON   FCD05.TYPEVT = substr(ZZ155.ARGTBL,3,3)
  AND substr(ZZ155.ARGTBL,1,2) = 'IC'
  INNER JOIN
  ( select cleevt as numcpt,
    max(concat(fcd05.datevt, fcd05.heumaj)) as latest_event_time
    from fcd05
    group by cleevt
   )  t2  ON t2.numcpt =  FCD05.cleevt
 WHERE concat(fcd05.datevt, fcd05.heumaj) =  t2.latest_event_time ) Table__60,
  ( SELECT CGD30.NUMCPT, ConvertDate(CGD30.DATVAL) AS  DATVAL, CGD30.MONMVT
FROM CGD30
JOIN ZZ137 ON CGD30.LIBSTD =  ZZ137.ARGTBL AND ZZ137.SWIT05 = 'Y'
JOIN (
SELECT numcpt,  max(concat(CGD30.DATVAL, CGD30.heumaj)) AS DATMAX from cgd30
WHERE CGD30.sgnmvt ='C'
group by numcpt) X ON X.Numcpt = CGD30.NUMCPT and concat(CGD30.DATVAL, CGD30.heumaj) = X.DATMAX
WHERE CGD30.sgnmvt ='C'  ) Table__63,
  CLD04,
  CDD20,
  ICD01,
  ZSD02
WHERE
  ( CDD05.NUMCPT(+)=CDD01.NUMCPT  )
  AND  ( CDD01.NUMCPT=CDD33.NUMCPT(+)  )
  AND  ( CDD01.NUMCPT=ZSD02.NUMCPT(+)  )
  AND  ( ICD01.NUMCPT=CDD01.NUMCPT  )
  AND  ( CDD01.NUMCPT(+)=CCD01.NUMCPT  )
  AND  ( CDD01.CODPDT=CDD06.CODPDT  )
  AND  ( CCD01.ENTITE=FCD03.CODETT  )
  AND  ( CLD01.NUMCLI=CCD01.NUMCLI(+)  )
  AND  ( CCD012.NUMCPT=ICD01.REFOPN(+)  )
  AND  ( CDD20.NUMCPT(+)=CDD01.NUMCPT  )
  AND  ( CLD01.NUMCLI=CLD04.NUMCLI_1(+)  )
  AND  ( CLD013.NUMCLI(+)=CLD04.NUMCLI_2  )
  AND  ( CDD01.NUMCPT=Table__60.CLEEVT(+)  )
  AND  ( Table__63.NUMCPT(+)=CDD01.NUMCPT  )
  AND  ( CLD013.TYPCLI=ZZ055.ARGTBL(+)  )
  AND  (
  CDD01.STAOPN  BETWEEN  '4000' AND '9000'
  AND  CDD33.SWICAP  =  'Y'
  AND  CDD05.TYPENR  =  '00'
  AND  CDD05.CMPSOL_22 + CDD05.CMPSOL_14 + CDD05.CMPSOL_50  <  0
  AND  (convertaccount(CDD01.NUMCPT)  NOT IN  (SELECT
  Table__63.NUMCPT
FROM
FROM CGD30
JOIN (
  OR   CCD01.SOLCRA + CCD012.SOLCRA  >=  ZSD02.PLAOFF_ORI
  OR   Table__63.MONMVT  <  CDD33.MONRBT_CAP+CDD33.MONRBT_INT)
  AND  (CLD04.TYPREL  IS NOT NULL
  AND  CLD04.TYPREL  IN  ('03', '05')
  OR   CLD04.TYPREL  IS NULL  )
  AND  (CDD20.TYPCTX  IS NOT NULL
  AND  CDD20.TYPCTX  =  '00'
  OR   CDD20.TYPCTX  IS NULL
  OR   CDD20.TYPCTX  =  ' ')
  AND  Floor( ABS (CDD05.CMPSOL_22 + CDD05.CMPSOL_14 + CDD05.CMPSOL_50) /  (CDD33.MONRBT_CAP+MONRBT_INT))
  >  0  AND  (CDD05.CMPSOL_22 + CDD05.CMPSOL_14 + CDD05.CMPSOL_50 < 0 AND (CDD33.MONRBT_CAP+MONRBT_INT) > 0)
GROUP BY
  CLD01.NOMCLI,
  CCD01.SOLCRA,
  CDD05.TYPENR,
  CLD01.PRNCLI,
  CLD01.NOMALP,
  FCD03.LIBETT_1,
  CDD06.LIBPDT_1,
  CDD06.CODPDT,
  CCD012.SOLCRA,
  FCD03.CODETT,
  CLD01.TELPRI,
  CLD01.TELBUR,
  CLD013.NOMCLI,
  Table__60.LIBEL1_1,
  Table__60.LIBEVT_1,
  Table__60.LIBEVT_2
ORDER BY
  14
when i query this SQL at Toad. its keep pointing at this place
and then after try to google at internet and found this website.
http://ora-00918.ora-code.com/
i try to fetch the data from here
CDD33.MONRBT_INT
now the error is gone but i try to put this query back to DeskI SQL panel, and try to run back the report but it still pop out the same error message. If you have any suggestion or why this thing happen kindly let me know.
skyjuice (BOB member since 2011-02-17)
