ERROR BODI-20030
Dear all BODI experts,
Maybe this is a clasical issue,
But before i wrote down this thread, i had already tried to find solutions for this BODI-20030 error and yet it’s still occured.
I’m using BODI XI R2 Acc
Designer 11.7.3.12
JobServer Not Responding
JobEngine Not Responding
Repository 11.7.0.0000
OS : Windows Server 2003 Enterprise 32 Bit
Database : MS SQL 2005 Enterprise
I had already created Repository for the BODI and when I want to configure the Job Server on The Data Integrator Server Manager below error is occured:
“BODI-20030: Error: Cannot save a job server to repository <DEMO_BODI_JOB_sa> version <11.7.0.0000> of the product. Please upgrade the repository to version <11.7.0.0000> or later.”
I already check in the Repository Manager that my repository is already 11.7.0.0000 and when i want to upgrade it, it’s said that the repository is already updated.
I already try to change my regional setting on the windows to English (United Stated), English (Australia), English (UK) but the problem is still occured.
Can someone help me out about this matter ?
thx
bernardy (BOB member since 2009-02-17)
There was something related to regional settings… Is you system configured to use a “,” as a comma separator?
Can’t remember the details and how it was solved finally.
Thx wdaehn for your reply,
first thing first i would like to ask, is there any difference whether i’m using Regional Setting for English (United State), English (Australia), English (UK) ?? or maybe there’s a specific English for BODI ? Anyway I’m using English (Australia).
As for the setting is like below:
Decimal Symbol = “.”
No. of digits after decimal = 2
Digit Grouping Symbol = “,”
Digit Grouping 123,456,789
Negative sign symbol = “-”
negative number format = -1.1
Display leading zeros = 0.7
List separator = “,”
Measurement system = Metric
I’m not sure about your question for comma separator, is it decimal symbol or digit grouping symbol ?
Need advice
thank you
hmmm, so that’s not the problem then…
:frowning: Anyone had ever solved this issue before ?
thank you
Dear all,
I had the resolution for this issue
Symptom
After installing Data Integrator and configuring the job server using the server manager, the following error message appears when trying to synchronize the job server with the repository:
“BODI-20030:Error: Cannot save a job server to repository <dwsbm_bodi_rep> version<11.7.0.0000> of the product. Please upgrade the repository to version <11.7.0000> or later”
Cause
During the install of the job server, a custom locale was specified.
Resolution
Edit DSconfig.txt in {LINK DIR}\bin
Set the al_engine parameter in the [Locale] section to _.
Synchronize the job server with the repository
Reset the al_engine parameter in the [Locale] section to its original value if required
:+1:
Well done. I repeat my statement however: Hmmmm, what could be the impact???
I will development let know. Thanks for sharing the finding!
