Hi BOB people. I need help about a problem occurred on BO Enterprise 6.1.0 running under Windows 2000 server SP4 with IIS 5.0.
After a reboot the system, when trying to run the page http://hostname/wiasp, after the login page I get the following error message (english translation from italian language ):
"Active Server Pages error ‘ASP 0115’ Unexpected error
/wiasp/scripts/login/login.asp
A trappable error (E06D7363) occurred in an external object. The script cannot continue running. "
The error occurred on line 43 of the asp module “login.asp” both the server is running and the server is stopped
I checked all rights on the directory, set to reading, writing, execution, etc also for the anonymous user
I tried to execute other asp scripts (writing data on mdb file) copied into the same directory; they run without problem
What do I do to fix this ?
I thank you for your attention and excuse me for my bad “Inglish”
i hope vince has managed to find the solution. As for me, i am having somewhat the same sympton but from another angle.
The 6.5.1 cluster manager was deployed as a single dedicated app + web + BO server, all-in-one monster, with IIS 6.0, in a Windows 2003 server.
It works fine so far, except for:
when i do a search from within Webi for a full-client document (have not tried webi docs), after entering the search string, i will receive the following message in the child frame:
Unexpected error
/wiasp/scripts/searchRXML.asp
A trappable error (C0000005) occurred in an external object. The script cannot continue running.
Active Server Pages error ‘ASP 0240’
Script Engine Exception
A ScriptEngine threw exception ‘C0000005’ in ‘IActiveScript::Close()’ from
‘CActiveScriptEngine::FinalRelease()’.
i cannot get the Admin Console running from a client web browser. On the server is it ok.
it displays a message saying “cannot login from client. Error: THe Business Objects System is not started. (ADC 00071).”
