ERR_WIS_30270
One publication has encountered the following error:
An internal error occurred while calling ‘getBlob’ API.
Recovery is done by re-registering the publication.
Please can you advise the cause.
its_ranjan (BOB member since 2011-02-16)
my experience is that WIS 30270 is the most generic of all WebI errors & you will probably never get root cause, especially since you can fix it with a work-around
if it is something that persists then you will need to raise ticket with SAP & probably do extensive debugging
buzz :australia: (BOB member since 2005-08-12)
Thanks for response. I will see if the logs help.
