Eroor during querry at CMC
Hi all,
As I try to make a querry on the database to create a preview report I got the following error:
ORA 121-54 TNS could not resolve the connect identifier specified.
The tnsnames appear to be all right .
Does anyone have any idea of how to solve it?
Tks
joaotelles (BOB member since 2009-02-06)
The most common cause: you have multiple TNSNAMES.ORA files and the one used is not the one it supposed to use.
newgun :us: (BOB member since 2007-08-01)
I believe thats there is only one tnsnames running, I just figure that the BO is accessing the db using other user that is not bobje… maybe thats is the problem…but when I changed it to bobje the CMS didnt started…
Sleeping 90 seconds before enabling the ports…
Creating session manager…
Logging onto CMS…
err: Error: Couldn’t logon to CMS
err: Error description: The system lab01 can be contacted, but there is no Central Management Server running at port 6400.
any solution…?
