Empty folders for Sybase power Designer Metadata
Hi ,
I Have created Integrator source connection for Sybase Power Designer in CMC. I have seen three folders in the Information steward metadata management . Those are Change Lists,Closed Changed Lists, Library
If I click on any folder inside there is no information .
But I have already check in the models to the Sybase Power Designer repository .
Thanks & Regards,
Ramana.
Ramana :india: (BOB member since 2009-04-30)
Ramana, did you run the Integrator Source from the CMC ?
Hi Ganesh ,
I have executed the integrator source . After execution only I can see the Power designer connection name under data modelling.
I have created the change lists in Sybase power designer .
Please find the attached screenshot of object browser/change lists for reference.
But If I opened my Information Steward power Designer metadata , there are blank folders including change list. Is any other settings I have to to do get the change lists . There are 2 change lists in the repository 1000,1002 but why it is not coming .
Thanks & Regards,
Ramana.
