HI all
i’m installing BO Edge 3.1 on windows server 2003
we want to use IIS
after the installation i have the following websites created :
AnalyticalReporting
crystalreportsviewer 12 as Default Application
Xcelsius
i have to run manually the WACS WebApplicationContainerServer (not normal i guess): this is the server that runs the CMC
do you think that configuration is normal ?
i tried to anable windows AD but no sucess ( i only succeded on importing a group and its users)
now i try to install the fixpack 1.3 and BO detects TOMCAT as a web server application but i don’t have tomcat, it’s not installed on the server
i don’t understand what’s happening
thank you if someone can help
claire
Claire (BOB member since 2004-11-30)
