I have 6 DP, the first lists all employee and there details (around 30k rows), the other 6 relate to Bonus types for example Options, Retention bonus. The nature of these Bonus is that an employee may be award more than one Retention bonus on the same date ie 01/Mar/2000 with each of these having a different payment date. I used a DP for each bonus type to overcome the duplication problem as the universe doesnt have contexts applied; it didnt work .
2). No Ive not linked all Dimensions in the DPS as the only dimension that is in all DPs is EMPID, so Ive linked on this
No I have not put ‘Multicube’ around my measures, Ive not used this before what does it do ? (Will try it though).
You have to link all dimensions that are in common. Those that aren’t in common need to be details or not in the report.
Details don’t rollup the way dimensions do.
What you’re describing tells me that you have multiple records for 1-Jan-01. That’s what’s supposed to happen. You might need to change the column definiton for date2 to make it a max or min of date2.
The other option is to create breaks and fold them up so that you only see the summaries.
