drillfilters functionality after scheduling
i have used drillfilters for State,TM,SM and set the hierarchies at universe as state–>TM–>SM.If state NY is selected TM filter should show only NY state TM.This functionalility is working fine.and scheduled this report to run now.when i select View Latest Instance option and select state Ny and TM filter is displaying all values irrespective of state.If i refresh the report its working correctly.So do i need to refresh the report to view the data after scheduling?or is there any other way?
Knr123 (BOB member since 2011-05-08)
I am not sure if you need to refresh to see the right results.
May be you can use the refresh on open option so that it automatically refreshes and populates the right results.
praveenmaddi (BOB member since 2011-05-10)
