Can I use drill down when my source is from “SQL generated” by my query in the “SQL Viewer”?
santana (BOB member since 2009-04-16)
Anyone knows this??
Please!!! Help me!
Do you mean you have hardcoded the SQL?
You can only build a scope of analysis from actual objects, so they at least would have to exist as actual objects in the query.
I can’t see this working if its heavily customised SQL.
Mak 1 (BOB member since 2005-01-06)
ok. thank you! santana
