Drill up from second level on chart
In one of the reports I saw there is drill down applied on chart up to 2 levels.
Level 1: % of profit/state
If user clicks on state it drills down to city level.
Level 2: % of profit/city
Now, if user click on city, it drills down to store level in city. If I re-click on store it drills up till city level, however if I want to go till state level and I click city its drills down instead of drilling up.
Can any one help me to understand drilling up feature here?
jayesh_deshpande (BOB member since 2009-07-21)
What if you right click and select drill up?
Prashant Purohit :india: (BOB member since 2009-02-18)
Thanks for reply.
On right click and selecting drill up it works fine. However I am not getting how it is not working normally.
Actually if there are multiple levels then initially it will drill down to lowest level on each click but after that it will again drill up to one level on next click then you have to select whether you want to go up or down, I guess that’s fine, right?
