Drill toolbar from BusinessObjects 5.1.7 to WebI
i created a report having drill toolbar for some columns
and i published that report in infoview
when i open it in infoview iam not able to see the drill toolbar
is it possible to make the users to see the drill toolbar and download the report after drilling in excel format
eswarsvr (BOB member since 2007-11-25)
let me understand the question. You created a report in Full Client and had the Drill functionality and now you want the same when the report is published to web. This is actually possible. Just check the user rights if he has the drill functionality.
bobjkb :india: (BOB member since 2004-03-19)
ForumAssociate,
I have a Full client report with drill functionality and i publish it to corporate documents.
In Infoview i was not able to find the drill bar.
As far as i know only webi reports can be drill down in infoview.
And full client or deski reports with Drill functionality works on the Deski application and doesnot work in Infoview.
Please let me know if i am wrong
DWH (BOB member since 2006-04-25)
Hi Friends
Ya i got drill funcionality in full client report and when i publish it infoview
iam not able to see the drill funcionality in infoview whn i open it in infoview
my question is it possible to see the drill toolbar of BO report when i open it in infoview
Iam using BO 5.1.7
Drill filters in full-client report (of BO 5.x, 6.x) simply don’t work (better said are not shown) when the report is displayed in Infoview.
That’s just the fact that you need to take into account.
Thanks for your reply,so what is the possible way to me so that users can use the drill function and download the report in excel
Should i create a report in WebI and publish ?
Is it possible to convert fullclient report in WebI report?
thanks and regards
I think there is no way how to convert full-client report to WebI report in BO 5.1.7 or at least I have not heard of such a way.
So I think your only chance is to recreate the report in WebI.
