drill to pie
Xcelsius 2008 SP5.
I have a pretty stacked bar chart of hours worked by various grades of staff (chosen via list builder). I can drill into this and capture the data from the bar clicked on by the user. I can put a pie over this - thus showing the detailed data from the bar selected by the user.
What I can’t figure out is how to control the visibility. I want the pie to appear when the bar is clicked on and disappear when the user clicks on a toggle/push button to close. But I can’t work out how to “capture” a mouse click on the bar chart. I’m sure it shoud be doable.
Debbie
As I understand it >
On Open, A1 = 0
Configure the Barchart to pass Its Value to A1.
Create a lookup range that uses A1 as a reference and supplies your Pie.
@ B1 have a formula that says =if(a1>0,1,0)
DynamicVis property on the Pie looks at B1 for 1
PushButton component (your “close” button) sends a 0 back to A1 on Push,which resets the A1 to 0, which sets B1 to 0, thus closing the Pie
Cairmor :us: (BOB member since 2008-06-05)
But A1 is never = 0 as I have to have a default selection in my bar’s drill…
Debbie
ETA: Oh I’ve got it. Had to create a dummy null series on the bar chart and set that as the default. Works perfectly now! Thank you. 8)
