My Required Report objects are:
Year, Month, Active Merchants Objects and Month Prompt
Report o/p is :
2008 2007
Sep Sep Variance
ActiveMerchants - 100 25 75
Requirement :
If i drill up on September then 2008Q3 data should come. But the problem is the Data is not getting changed based on the Month, Quarter,Half Year and Year. (Because of month prompt)
Below is the SQL with Month Prompt :-----------------------------------------
SELECT
V_DIM_CAL_MONTH.YEAR,
V_DIM_CAL_MONTH.MONTH_NAME,
Sum(distinct(DW_MTH_SUM_MERCHANT_STATS.ACTIVE_MERCHANTs)),
V_DIM_CAL_MONTH.HALFYEAR,
V_DIM_CAL_MONTH.QUARTER
FROM
V_DIM_CAL_MONTH,
WHERE
( V_DIM_CAL_MONTH.MONTH_IN_YYYYMM=DW_MTH_SUM_MERCHANT_STATS.MONTH_ID )
AND
( V_DIM_CAL_MONTH.MONTH_NAME =‘SEPTEMBER’ )
AND
( V_DIM_CAL_MONTH.YEAR between (to_char(sysdate,‘YYYY’)-1) and (to_char(sysdate,‘YYYY’)) )
GROUP BY
Without Month Prompt in the Report :------------------------------------------
Report Objects : Year,ActiveMerchants
Report Output :
Year ActiveMerchants
2008 150
2007 100
If i drill on year column(2008) then data is coming for Half Year:
Half Year ActiveMerchants
2008H2 150
If i drill on Halfyear column(2008H2) then data is coming for Quarter:
Quarter ActiveMerchants
2008Q3 150
If i drill on Quarter column(2008Q3) then data is coming for Month:
Month ActiveMerchants
SEPTEMBER 100
AUGUST 50
SQL for the Report is :
SELECT
V_DIM_CAL_MONTH.QUARTER,
FROM
V_DIM_CAL_MONTH,
WHERE
GROUP BY
Database Output for the above SQL is:
Year Active Merchants Half Year Quarter MonthName
2008 100 2008H2 2008Q3 SEPTEMBER
2008 50 2008H2 2008Q3 AUGUST
2007 25 2007H2 2007Q3 SEPTEMBER
2007 75 2007H2 2007Q3 AUGUST
Please let me know how to acheive the drill properly with month Prompt ?
It is very Urgent!
Thanks in Advance
Lakshmi.K
lakshmi.k (BOB member since 2008-08-25)
