Drill Option is not available for new users
I have a BO XI 3.1 set up. I am facing a problem that the new users i am creating, do not find drill option in the existing reports. whereas if i login using administrator I am getting the drill mode. I logged in as a newly created user and looked at the preferences as well but there also the drill options are being displayed as grayed out.
Can anyone suggest what might be the cause for the same. Thanks in advance for any help or pointers to the above problem.
Vikas
vikaskhare (BOB member since 2009-03-05)
See the below link
[/url]
Raj_admin :india: (BOB member since 2008-12-04)
Hi Raj,
Thanks for the response. But somehow my problem stll remains the same.I went thru the post and it says :
[ In the CMC
BusinessObjects Enterprise Applications
Web Intelligence > Click on Advanced to see the user group settings
Enable Drill mode is there[/size] ]
But I could not find any advance option when i clicked on the
Application > Web Intelligence in CMC :frowning:
Vikas
What you need to do is double check the security settings on the WebIntelligence application using the CMC. (Manage UserSecurity)
Thanks a ton Sebastien!!
It worked :+1:
