Drill on freehand sql webi report
Hi Experts,
I have webi XIR2 report. I have used freehand sql to create the report.
Is it possible to drill on freehand sql webi report?
Really appreciate your suggestions.
Kalyani (BOB member since 2007-02-26)
Drilling requires hierarchies, which are defined in the universe. With Deski you could define a custom report-level hierarchy, but not in Webi. So the answer is “No” which is yet another reason not to use freehand SQL.
Ever. :stuck_out_tongue:
