Drill grayed in BO 6.1B
I am not able to swich drill mode in e-fashion report i given expert(everything granded) predefined setting for the user for business objects.
Verified the e-fashion has hierarchy in universe and pulled same objects in reports.
I tested with other my business universe,but no luck?.
Great if any one could help me out.
Businessobjects 6.1b
Nidhi
kklingam (BOB member since 2003-12-01)
I suppose … you are facing this problem because you are not dragging the Object which was defined in the heirarchy at the Universe level…
check from your side that you are dragging the same object which is defined in the Heirarchy.
smarty07 (BOB member since 2006-01-30)
Or See here… https://bobj-board.org/t/46914
Steve
snakeboy :uk: (BOB member since 2003-12-02)
