Drill function disabled
I have applies drill filter in desktop report but when i am exporting the same to webi i don see any drill option .
Can anybody help?It’s an urgent requirement i have developed whole report in desktop now in webi its not working.
Thanks in Adv
abc
abc (BOB member since 2007-06-05)
Drill filters in Deski reports are not shown when the report is displayed in Infoview. That’s how it works. No workaround.
If you want drill filters and you will use Infoview then you have to create the report in WebI.
And is it like if i develop report in webi with universe connected to test and later if i re-export the same universe with different database connection the earlier developed report will not pik up data from the new database ??
i am facing issue in accessing new data
If you change the connection parameters in the universe (you repoint the universe from one database to another) then a webi report that uses the universe should reflect the change and should access the new database.
