Drill filters in Crystal reports
Do we have any way to create Drill filters in Crystal reports (I am using Crystal 2008)?
thanks
Praveen
kk@bi (BOB member since 2009-06-16)
In Crystal, the nearest equivalent are parameter fields.
The main issue with parameters is that they are completed BEFORE the report queries the database and before the report runs. You can use parameters in the select expert, in formulas or they can be placed on the report.
Any parameter you create and use in crystal will be prompted for before the report runs.
Hope this helps.
smptraining :uk: (BOB member since 2009-07-07)
Hey…thanks for the swift reply
I want to run data for all the parameters without any prompts and wanted to see data based on some drill filters similar to what we do in Web intelligence report.
Whether drill filter is possible in Crystal reports or we have only one option to filter the data i.e. go through the prompt selection before run the report? Please advice.
Hi …
I have the same question. Do we have drill filters option that is there in webi available in Crystal Report 2008.
Shirin
Shirin (BOB member since 2008-11-10)
