Drill down
I am trying to setup hierarchy and drill down on a report. The table has 30 columns and each cloumn represents a level from 1 - 30. I want to be able to drill down from one level to another without having to put all 30 columns in the report.
eg
Column name \ value
L1 \ 0005
L2 \ 0006
L3 \ 0007
L4 \ 0008
etc
So when the user runs the report, they can enter any of the values. I currently want only one column “Levels” to be used for L1,L2,L3,L4 so if the user enters 0005 I am able to drill down from L1 to L4 and other levels, but if the user enters 0008, since there is no column with the L4 object, I am not able to drill down. I have tried to dynamically replace the values in the column “Levels” which works but when I enable the drill option, nothing happens.
Any thought other than putting all 30 objects in the report?
oluoluchukwu (BOB member since 2006-09-22)
Hello.
A hierarchy is defined by its list of dimension objects. As such, I think your only solution is going to be to include all 30 “L” objects in your query.
lgonzalez (BOB member since 2002-07-17)
I have no problem listing the objects in the query, I just don’t want to list all 30 in the report. I would like to have one column used to represent all 30 which I am able to do using IF statement, but using that does not allow me to drill down.
But that’s how drill-down works - you drill down from dimension object to dimension object. And you don’t need to display all objects to drill-down. In the original, high-level table, you only need to display the top-most object in the hierarchy. When you begin drilling down, this column will change to the next dimension object in the hierarchy.
I have a report that requires only 4 columns. I would like to use column 1 to represent and hold the values for 30 objects L1,L2,L3,…L30. each object will contain only the values that pertains to the level they belong from 1-30.
L1 - 20,
L1 - 21
L2 - 30
L3 - 40
L4 - 50
So if I select 20 or 21 for the prompt, I want column 1 to show the values for the object L1. If I any other value, I want the corresponding object for that level to be displayed in column1. I am able to put the object L1 in column 1 as the default and be able to drill, I am able to change the object in column 1 to another Level object but I do not get the option to drill.
I have the same issue, I would like to use column 1 to represent and hold the values for 12 objects L1,L2,L3,…L12. How can I achieve this?
Regards.
Aussie2582 (BOB member since 2008-04-16)
If all you are trying to do is to show the values, then this should work, you create an object and place this in the object “=if ([Level Number] = 1; [L1]; if ([Level Number] = 2; [L2]; if ([Level Number] = 3; [L3]; if ([Level Number] = 4; [L4]))))”
This will check for the respective level and replace the value of the column with the value
