I faced problem for drill down function. When i drill down the dimension in Webi report, the results is correct… When i drill up… all the figures wrong…
Please advice…
thanks
stupidcute (BOB member since 2009-08-19)
Please advice…
thanks
Please explain in detail.
Also check if there is a problem with merge dimension.
avbaby (BOB member since 2009-05-09)
Hi avbaby,
Thanks for reply.
For example : Company, Product, Month and Volume.
When i drill down 1st level of product, then it shows volume results is correct. Drill down to 2nd level product, results correct. But when i rollback… drill up to 1st level of product, the results is wrong…
Please advice…
thank alot…
What is the heirarchy in your case. Is it Company->Product->Month.
