Drill disabled on multiple universes
Hi all,
I have a strange problem, we are using xi r3 and database is db2. We have two universes, one for sales and other for stock. When we build reports of those universes separately we can drill down fine. The problem occurs when we build a report from both the universes then the drill button is not enabled.
We have the same hierarchy in both the universes and merge dimension works fine when displaying data in the report.
Any ideas why this might happen and if you have some thoughts on the probable solution then that would be great!
Thanks in advance!
himu1980 (BOB member since 2010-06-30)
Hi…any hints would be great please
Are you using Infoview or Richclient?
chavala :india: (BOB member since 2007-01-08)
I am using infoview
