Drill By facility in webi
California, because [City] is the dimension below [State]. Instead, you select Drill by from the drill menu and then you navigate through the dimensions on the Products hierarchy by selecting the sub-menus until you reach the [Lines] dimension.
Is it possible to use drill by facility on State itself and see all the line dimensions under all states instead of just california
pulla (BOB member since 2010-05-12)
Yes. One of the options in the list of States should be All States
tmarion :us: (BOB member since 2002-08-20)
Can you please explain in detail
It isn’t drill by, instead it is drill across. Every time you drill a new listbox is added to the drill toolbar. TYhe first item is each listbox shoulkd the All objectname
