Double drill
I have a hierarchy in universe, Center>Manager ID>employee Name,
Now in the report, after drill from Manger ID we come to columns showiing
Manager Name and Employee Name.
Now, I need to be able to click on individual employee to see his data.
Since this is end of hierarchy, i cannot do so…
Need help and ideas…
:reallymad:
americanmc :hong_kong: (BOB member since 2009-12-31)
You need to set the hierarchy in the universe Center>Manager ID>employee Name> employee data (object) or you can create one more report for (employee data) as child report and make a hyperlink from parent report and drill down to child report (to view employee data).
Arun
arung :india: (BOB member since 2007-07-18)
You can also create an hierarchy within the report to show further drill.
However, you need to set all levels of hierarchy again in the report.
Hari
harinath :india: (BOB member since 2006-01-04)
Setting up one more level of hierarchy will only allow you to see the same fields/columns/information at the employee level too but if you want more details at the employee level, you have no other option but to go with the opendocument approach. which version on BO are you using?
anubotu :albania: (BOB member since 2010-04-29)
