Does Where operator work different in DeskI and WebXI?
Hi all, i have tried to find documentation about my issue with no success :frowning:
Here is the problem:
i have a report with a variable that use the “Where” operator.
In Desktop Intelligence (XI R2),
If i write the variable in this way:
Sum(<SellOutStdQty(SellOut_YTD)> Where (<MerchYear(SellOut_YTD)>=2008 ) )
it works!
If i write it as:
Sum(<SellOutStdQty(SellOut_YTD)> Where (<MerchYear(SellOut_YTD)>= ) )
it does not work! (in this case is equal to year(CurrentDate()) )
It returns “Syntax Error DMB0007” but I am not able to find documentation about DMB0007 error…
The weird thing is that the second espression works fine on WebIntelligence (XI version…)
Any suggestions?Does it exist a pdf document with the list of different behaviour between deski and webi functions and operators?
Thanks in advance
M.
bilux_team :it: (BOB member since 2008-01-17)
mmmhhhh maybe here FAQ: Reporter there is a tip…if only the search function of this site do not stopp all words i use to search for my problems!!!
btw i do not understand why it works on webi…
thnaks
It is not the problem with Where it seems… but with the angle brackets you use in your formula…
In Web-I, you have to use square brackets…
for e.g. Use [SellOutStdQty(SellOut_YTD)] instead of <SellOutStdQty(SellOut_YTD)>
Also where accepts only constants to be compared…
So it is better always to use If() instead of Where.
Hope this would help you.
Jansi, in WEBI (changing brackets of course) it works.
I do not understand why it works on webi but not in deski…
thanks
ciao
