We’re on BOXI R2 on windows.
I know that you can use the Enterprise SDK to retrieve a list of universes in your environment and some details of those universes.
You can also document a SINGLE universe using the designer SDK.
My requirement is to retrieve a list of ALL universes and their parameters. Specifically the END_SQL parameter at the moment, but I’ll want to add more parameters in the future.
As I see it, you can’t retrieve the END_SQL parameter from the Enterprise, so it’ll have to come from the designer SDK. Is there a method for retrieving details for all universes in designer?
You can do it with connections very easily:
For Each Connection in Designer.Connections ...
But as far as I see it, you can’t do this with universes without having the universe saved locally, and opening it.
We have a large number of universes, and want to be able to check that all the parameters for them are correct, without having to open each one individually.
Deano
(BOB member since 2006-06-19)
