Documentation, metada problem?
I am trying to do some documentation for the existing universe, like put description for each object and class at the designer. Someone mentioned that we could use oracle bridge to transfer the field information from Oracle metadata to designer, is that a practical idea? Any one tried before? Or it’s better input it manually? Any suggestion or comment is apprecited. thanks
lavinaluo (BOB member since 2005-02-14)
If i understood your question, the below link may work for you. By using that you can download the object descriptions and names and also make updates back to the universe by just updating your excel sheet. this tool works like a magic!!https://bobj-board.org/t/21029
venira :india: (BOB member since 2004-12-07)
I don’t know if “magic” is the right word, but I’m glad you found it useful.
