Hi, is there a way to document all the formulas in a web report?
Hi, I solved this with a python script running on a local WID-file copy of the webi document.
The wid-file is the local working copy used by the Rich Client.
And you’ll need python / jupyter notebook or lab to run the code.
initial version is here: GitHub - CoenHordijk/SAP-BO-WebI-file-analyzer: Python tool to analyze SAP Business Objects WebI documents but i’ve made some upgrades, like exporting the variable formulas, since then which are not checked in yet. Let me know when you are interested
Great tool ! Love it.
You may also use the RESTful Web Services to get the list of variables for a document in the CMS and then also get the formula (definition) for each variable.
variables-list URL: …/raylight/v1/documents/[documentId]/variables
HTTP Method: GET
variables-details URL: …/raylight/v1/documents/[documentId]/variables/[variableId]
HTTP Method: GET
This is brilliant and so helpful, thanks!
I looked into this, and it is very promising, and more sustainable than cracking open the WID files. The only thing I can not find in the API is information about Reference Variables, which is needed to get the full picture for variable lineage / usage in the report. Planning to submit the stuff I got in the upcoming weeks in GitHub.
Hi, here’s some Python code to analyse BO documents data objects via API Access:
It offers insight in dependencies of data objects in a document, as well as all kind of properties of data objects.
