document domains...
We also copied our 4.1 repository (sl-server 6.5) and upgraded to BO5. I had the same errors in BO5.0 when exporting/importing universes in designer.
Apparantly BO couldn’t replace (delete) existing custom LOV’s in the repository
when exporting a universe.
When I enabled the setting ‘delete corporate documents sent by other users’, everything worked fine.
Hope this helps,
Peter Smets
FortisBank
We have been copying our universes to a test repository, from 4.15 to 5.01… copy all the universe and lov files to 5.01 (on the designers’ box), then we export. Sometimes the export gives the error that an object in the LOV exists already, can’t overwrite. Then, on the import from within
Webi, we get an error that the document domain is different / can’t import the LOVs…
