How can I check if the document agent is up and running? There must be a simpler way than looking at the TIMESTAMP table in the repository.
hans
hans
If it runs as an NT service, open the Services and look at the DocAgent service as you defined it.
If not, open the console within BO.
Pierrot
hans
try to send a document to it…
hans
OR search: Mail to listserv@listserv.aol.com, ‘search a_phrase in BUSOB-L’ Unsubscribe: Mail to listserv@listserv.aol.com, ‘unsubscribe BUSOB-L’
DI Walter Muellner
Delphi Software GmbH, Vivenotgasse 48, A-1120 Vienna / Austria Tel: +43-1-8151456-12, Fax: +43-1-8151456-21 e-mail: w.muellner@delphi.at, WEB: http://www.delphi.at
Hans wrote:
How can I check if the document agent is up and running? There must >>be a simpler way than looking at the TIMESTAMP table in the repository.
Simply bring up DAS on another machine if it opens in console mode the the primary is still up. If it does not you have problems.
Sincerely,
Thomas Nather
Penske Logistics
email: Tom.Nather@Penske.com
Ph: 216-765-5787
Fax: 216-765-5666
