The following information was taken from this address on the Oracle Website…
http://www.oracle.com/support/bulletins/net/net8/html/ora6413.html -----
Article-ID:
Circulation:
Affected Platforms: 615 - MS Windows 95
Affected Products: Oracle TCP/IP Protocol Adapter Problem Description:
You recently upgraded to Oracle8 and upgraded clients to Net8. Now when you try to connect via sqlplus you are getting an ORA-06413.
06413, 00000, “Connection not open.”
// *Cause: Unable to establish connection. // *Action: Use diagnostic procedures to ascertain exact problem.
Solutions and References:
DO NOT SHARE DIRECTORIES WITH SQL*NET
Article-ID:
For-Problem:
Circulation: ** ORACLE INTERNAL ONLY **
Affected-Platforms: 615 - MS Windows 95
Affected-Products: Oracle TCP/IP Protocol Adapter
Problem Solution:
Verify that you don’t have SQL*Net 2.x and Net8 in the same directory. You can’t install both of these in the same directory and share their tools.
